Yeah so the temperature of the engine was going all over the place. Basically when I didn't have the AC going it was going up in heat. When I turned the AC on it would go back down.
To your original question, some that have had the TSB applied said it helped and others said it didn't. There's a software update and new driveline (4WD models) that comes with the TSB. If you live in a colder weather climate and have 4WD, the driveline update should make a difference. The new driveline comes with a softer damper around the carrier bearing, which especially when cold, does a more effective job of absorbing driveline vibrations.
As far as turning off VCM, have you looked into S-VCM? It does not alter the coolant reading on the dash and keeps VCM turned off no matter what the driving conditions are. I installed one awhile ago and it works as advertised.
I am using the S-VCM controller as well and I did notice a slight drop in the reading when it is in "normal" operating condition, but the reading hasn't varied that I've noticed. Once the heat range gets past a certain parameter the S-VCM will remove itself from the signal path and you will receive and "actual" heat value. Otherwise, the just-slightly-below-normal reading is due to the resistor.
We went ahead and sold the Pilot. To much unknown especially given the history. We loved the Pilot but we will not be purchasing another.
