Honda Export Service Bulletin
02-055
BACKGROUND
Some water pump castings are not within specifications because of a manufacturing die problem. As a result, the timing belt tensioner pulley is misaligned. This pulley misalignment causes the timing belt to contact a bolt on the cylinder head, eventually damaging the belt. In the worst case, a broken timing belt will cause the engine to stall, which could result in a crash.
Affected Vehicles:
2003 Pilot:
KA: From VIN 2HKYF1...3H513603 thru
2HKYF1...3H517522
KX: From VIN 2HKYF1...3H900004 thru
2HKYF1...3H900033
Printable copy of TSB 02-055
02-055
BACKGROUND
Affected Vehicles:
2003 Pilot:
2HKYF1...3H517522
2HKYF1...3H900033
