1 - 2 of 2 Posts
2015 Honda Pilot LX with 68k miles.
Has anyone else had the black plastic trim that runs along middle of each side of the car come loose and/or fall off?
The piece on the drivers side of ours was found to be hanging off today. It looks like its just held on with some type of adhesive tape. The heat here in GA must have caused the adhesive to fail.
Has anyone else had to fix this? And what did you find was the best way to fix it?
I'm not familiar with the tri on the Pilot specifically,. but... Side trim is often held on with a particular double-sided trim tape that you can buy from an auto paint store or even Amazon. Pull the old stuff off, clean thoroughly with wax-and-silicone remover, apply the tape to the trim. Then add a line-up guide of blue painters tape so you get it perfect the first time you press it in place. I'm sure there are yeautoob guides that show the process.
Reactions: Randy Sansom
1 - 2 of 2 Posts
