What is it and how do we get it fixed? We don't live close to a Honda dealership so our mechanics have just been changing stuff and can not tell us what it is. I'm not sure they know.
From page 64 of the Owner's Manual:
132740
It's a Honda-specific system, so if your mechanic can't handle it you might need to bite the bullet and take it to a dealer, or at least a Honda-savvy mechanic.
Use the OBDII port pin 4-9 jumper trick to read codes or if you cannot figure out how to read them, then make a video and post here.
You have to count flashes and continue filming until the flashing codes begin repeating, as there are usually more than one code.
The codes come in the order of detection, i.e. if you had a bad ABS wheel sensor, then it would come first, followed with other codes.
Watch youtube for examples of how to read flashes. First 4 means 10, so if you read 4-5-1, then it is 15-1. HTH!
Make sure you didn't accidentally turn VSA off. Hit the button on the left side of the steering wheel that says VSA and see if the light goes off.
It comes on when the gauge is below 1. When it comes on it's constant and it has a fan sound. When we try to accelerate it seems strained the only way to stop it is cut the car off and cut it back on.
