1 - 8 of 8 Posts
OK guys I am having an issue with the transmission fluid getting hot for my husband doesn’t think the fans are running when they should have replaced temperature sensors replaced the thermostat as well the light comes on for that fluid it A/T light
Do the fans ever turn on? If you’re sitting at idle for long enough they should turn on before the coolant temperature gets too hot. I think the passenger side radiator fan turns on once the ac is enabled.
The ATF temp won't trigger the engine coolant fans.
You most likely have a bad atf temp sensor.
I agree with Rocky that ATF temp will not trigger the fans, but if the fans are not turning on that is an issue. If one fan turns on and the other one doesn’t swap fan relays for starters.
Which sensors have you replaced thus far?
Discussion Starter #7
We changed both temp sensors and my bad fan is working the reason I said ATF was hot the A/T light came on I hook it to diagnostics I still get PO128 which is temp related and PO 420 which is catalyst system related
1 - 8 of 8 Posts
