Transmission system problem light just popped up on my dash. I am a bit worries. Just had the dealer recommend Ed transmission system flush. $420.00
Then the blind spot info system problem light came on.
Turned the car off and then on again. Warning lights disappeared.
Should I be worried?
Is it a 9 spd or 6 spd? as far as I know for the older models Honda doesnt recommend flushes on their trannies. Not sure if that is the same for the newer models and or the 9 spd. How many miles? Still under warranty? I would be concerned since both lights came on and I don’t see how a flush would help that.
Drain and fill Is all I would multiple times. Not sure if thats what they meant but not sure how a few quarts of fluid would cause or help that.
I would definitely bring it back and let the dealer know about it and see what can be done. It's a good practice to leave a record just in case.
You definitely need to bring it back to dealer and have them check it, after tranny flush then light comes on doesn't sound good , it will be recorded in the Honda maintenance records in case something to happen down the road.
