1 - 2 of 2 Posts
hello just replaced my transmission (2003 pilot) and got my rad (trans cooler)flushed ,just want to make sure i have the lines from the trans to rad connected correctly ,so looking down into the engine compartment standing in front ,the right trans line , (off the trans) gets clamped beside the starter then connected to the left rad line tube stub ,the other line off trans goes to right side,on rad, tube stub Thanks
as I recall it's difficult to hook them up in reverse due to the length being a little different. However, if you did hook them up opposite, I don't believe there isn't really any difference in which direction fluid flows.
1 - 2 of 2 Posts
