Lots going on here, and I'm hoping someone can help me focus my thinking.
Our Pilot is a 2005 with 130,300 miles. Two days ago, it began hesitating when I tried to accelerate on a few trips around town. The engine would rev up as if I were accelerating, but it was as if the transmission wouldn't "catch" or struggled to get traction. It did accelerate, just more slowly and with less power than normal. Once it reached a certain speed, perhaps 30 mph or more, it operated/shifted as normal, though occasionally (not always) upon another stop/start it would hesitate upon acceleration again. The behavior repeated when I shut the Pilot off and restarted. I also believe this happened when I shifted into reverse though I didn't test that thoroughly.
Also, at some point the heater stopped working. It blew air, but the air was cold, even well after the Pilot should have been warmed up. I have no idea whether this would be related or not but the timing seems too coincidental.
Once I got home, I noticed some red fluid leaking on the garage floor. I opened the hood and saw moisture all over the left side of the engine. I first assumed this to be the same fluid, but I also noticed the lid on the washer fluid reservoir opened. I had filled the reservoir with orange washer fluid the day before and now the lid was not secure. (Am I correct to think this was probably a non-issue? Wouldn't any washer fluid that splashed out evaporate or escape harmlessly?)
I backed the Pilot into the driveway, cleaned the red fluid from the garage floor, cleaned the engine of whatever moisture was all over it, then pulled it back into the garage and put cardboard underneath. A few more drops of red fluid ended up on the cardboard, but then it seems to have stopped. I have not driven the Pilot in two days, and due to other weekend commitments didn't even get the chance to actually check the transmission fluid level.
A few other notes that may or may not be useful:
- The transmission fluid was last flushed at its 90,000-mile servicing in December 2012.
- Weather seems unlikely to have been a factor. I live in Iowa and it was a typical February day, probably around 40 degrees and sunshine.
- The maintenance light came on the day before I noticed this problem. However, I assume this is unrelated, as the manual says this light comes on/stays on 7,500 miles after the previous servicing, and that was almost exactly 7,500 miles ago, in June 2016.
- At its most recent servicing, the vehicle was in overall good health, including transmission fluid levels.
So what should I do next? Is it safe to drive? Is there anything I can do myself or should this go right to a mechanic? We're right at that point where I would consider trading the Pilot in if this is a major repair of, say, more than $1,000 or $2,000.
Any thoughts are welcome...TIA.
