I know the fluid needs to be checked when the trans fluid is at temperature, do you see fluid on your dip stick when its cold?
Yes, I believe that the lower mark is the cold level, and the upper mark is the hot level. You should be checking the level with the Pilot parked in a level spot and the engine off. If you just went for a drive, give it a couple minutes for the level to stabilize. Don't try to check when the engine is idling.
Also if you just changed the fluid, don't be surprised if you can't see a distinct line where the level is. Just make sure that the bottom hole has fluid in it and streaks upwards.
--Chris N.
Yup, there is fluid on the stick when the tranny is cold. But as STMech noted check the fluid level with tranny hot and engine off.
Don’t forget to smell the fluid too. It should have a semi-sweet non burnt aroma to it.
