1 - 8 of 8 Posts
Has anyone installed a 7 pin trailer wiring harness and brake controller on a 2016 Pilot that doesn't have a factory towing package? I thought I would give it a try by plugging in a trailer wiring harness and a trailer brake controller harness into the connectors/sockets (in the left rear and under the dash) in my Pilot. I get trailer lights and the brake controller powers up but no brake power or charging power at the trailer.
I was hoping the necessary wiring would be there - I thought it would be cheaper for Honda to use a "universal" whole car wire harness rather than 2 separate harnesses. There's even places for the fuses. One of the fuses was actually there.
Am I stuck with running my own wires for trailer brakes and trailer battery charging? Thanks.
Are you sure you plugged in everything you need to get power to the brakes? The Honda harness comes with fuses and relays for under the hood and another relay box in the rear.
Yes, all the plugs (on the trailer wiring harness and the brake controller harness) are plugged into their respective connectors.
Thanks, but it's not a Honda harness, it's an after market, Tekonsha, harness. It came with fuses. I put them in.
Like viper said, check the fuses. I think theres a 30 amp and a couple 20s. My brake controller doesnt activate until its plugged in to a trailer
Tekonsha harness should be good. A good place for information on all things towing is etrailer.com They sell all the stuff, and they have lots of DIY videos on how to install it. Check them out for a video on harness install in the 3rd Gen Pilot, I'm pretty sure there is one. You may have missed one of the fuses that needs to be installed in the engine bay.
They have several videos for the tekonsha. I just removed my 4 pin and installed my 7 pin. They both plug right in. They do require a trailer mounting bracket.
My year old 4 pin will be for sale soon
1 - 8 of 8 Posts
