Well some Pilot purists prefer the OEM hitch because when unused it sticks out less than the aftermarket. I don’t mind my hitch sticking out a bit.thank you..i just hope the bumper cover is the same also
Imust be a purist...lol..thanks againWell some Pilot purists prefer the OEM hitch because when unused it sticks out less than the aftermarket. I don’t mind my hitch sticking out a bit.
I did everything myself. One person. Do a search and you’ll see everything from part numbers to time and costs. In summary, I bought everything for under $600 (hitch, wiring harness, and hands free kit (need a shortened version when you add a hitch) and it took under 3 hrs for everything if I recall correctly.I saw the installation instructions and it looks fairly straight forward. Has anyone done this install themselves, how long did it take, was it hard and did you require another person for assistance?
Tom
This part of it, I took about 25 minutes. Mainly because I had to look up how to lower the tire. I then used the tire itself to support the hitch part way till I could lift up one side and get the bolts started. Then shifted the tire to the other side for support off the ground, and got bolts started on the other side.Thanks, yeah I don't think I'll be towing anything but a bike rack.
Main difference between OEM and aftermarket is more 2+ inches of ground clearance. Aftermarket goes under the existing bumper. OEM version is set in between the bumper.A little bit of info that might help people. The trailer hitch is the same as the Acura MDX and on amazon you could probably find a CURT for about $150.00 its the same exact part Number
No. You can’t really cut down the sensor antenna as it runs the full length. The hitch version is shorter and only senses movement on the right side of the bumper.From the Instructions for the install it appears that you dont need to buy a different hands free adapter, you just cut down the one that already exists. Is that how everyone else reads it?
I installed my hitch yesterday myself and had to do the same thing. I ended up using some industrial glue to hold it in place. But it does works but with more limited range. I was able to convince the dealership to modify my original hands free adapter by cutting the plastic down to the correct size and routing the long antennas around the hitch receiver.
