Hi All,
The past couple summers we spent a week at Silver Lake Michigan and time in the dunes and are planning another in July. My '09 Pilot goes awesome in the dunes, but my question is: When I run my tire pressure at 15-18 lbs it throws a light on my dash and with the light on I can't turn off the traction control causing the rpm's to cut out at the top of the tall hills pretty much ending the momentum. I've tried pulling the traction control fuse but that cuts out my front wheel drive leaving me with rear wheel only. Any Ideas how to run low tire pressure and disable my traction control at the same time?
Thanks,
HJ
I've heard of people building "pressure vessels" using PVC tubes and placing their sensors in the PVC tube while running standard valves in their wheels so they can adjust the pressure. This happens to more vehicles than just the Pilot.
