Went to start my Pilot on Sat and it just clicked. Pulled the battery out and replaced it, it fired up right away with new battery, but the Traction Control / ABS / BRAKE dash lights are on.
Hooked up a scanner and had no codes. Any ideas?
Sounds like there is codes BUT the scanner you are using is not designed to see the codes . Basic code scanners will not see those codes.
If you didnt have this light before the battery change, I'd disconect the negative terminal for a few minutes, then reconnect. If the light is still on, I'd check fuses related to that system.
