I've added a column to the VIN table (see link in my signature below) to track problems. Append to that thread with your VIN and I'll mark whether you have the problem(s) or not.
Please discuss there here, but append only to that thread if i need to update the table.
I also want to add a link to a thread discussing each problem there. If I don't put one please suggest one.
I still think most PILOTs are problem-free, but it helps for folks with problems to be able to collaborate. This is the intent of this additional column in the VIN table, not to exaggerate PILOT problems.
Here are the problems I could think to add so far:
0=none!
s=starting; [link to thread here]
g=gas tank slosh [link to thread here]
c=window scrunch [link to thread here]
v=70 mph vibration [link to thread here]
I can add +/- to each to indicate you do or do not have
the differnt problems if you like. -s +g for example meaning you
do have gas tank slosh but not the starting problem. Suggestions welcome.
Discussion Starter #3
Yes you're doing it right...
But I'd like folks to append that info to the VIN table thread, including their VIN. If everybody does it in the same format,
it makes it easier to do lots of them (so my brain doesn't have to switch gears so much)
e.g. Something like the following would be nice to post to VIN table thread:
Add to Problem column:
18440 Ferdball sc
I'll put yours in, Ferdball.
000747 PChiu Canada.
s yes occasional
g yes occasional
c yes occasional
v no
Thanks for your good work, it really helps for satisfy and not-so-satisfy (not that lucky as others) owners
How about add in
Road noise (not wind noise) yes
Trim piece borken - rear air vent yes
- panel in cargo area yes
- trim pieces around interior tailgate yes
- 2nd roll bottom door sill pop up yes
Saggy leather yes
Clicking driver side suspension yes but gone by itself
Dent by seatbelt on B-pillar (both sides) yes
Steering wheel not horizontal yes
Thanks.
