Hey All,
I got a low pressure indication when we drove up to a cold location. I filled the tire so that the pressure matches the other 3 tires. I looked online and in the manual for the reset procedure and don't have any luck.
The menu option doesn't appear in my Settings-Vehicle menu.
Any help would be appreciated. I filled the tire a few hours ago... low pressure light is on, but the pressure is 30 psi.
There isn't a reset, you have sensors in each rim, yours read actual pressure in real time. 30 psi is low, look in your drivers door jam, the tire sticker will tell you the proper pressure.
You just drive and the system will pick up the readings from the individual tire sensors. It may take a mile or so for readings to adjust assuming all your sensors are functioning as they should. Keep my tires at 35psi cold
Thanks All! Tires are properly inflated and the light turned off. It's nice not to have to reset the sensors after refilling the tires.
