My TPMS dashboard goes on about 10 minutes into every drive.
When I turn off the engine, and restart, the same cycle happens.
All four tires are in inflated to 32 psig.
Does anyone have an idea of what the problem is?
One (or more) of your TPMS sensors is bad, most likely because of a dying battery. Any decent tire shop has a tool to scan which one(s) you need to replace.
Reactions: 97trophy
Likely all of them if they are original.
Indeed, so to avoid this happening piecemeal with each one going forward, may as well change them all out at the same time. If you can time it concurrently with changing or getting new tires, it'll save labor and hassle.
