Our dealer installed the towing pacakge. Looking under the hood, how can I tell if the "coolers" where installed? I think there are supposed to be two, one for the tranny and the other for the power steering. Is there anything else I need to check for? Thanks!
yes, there are two of them. They are both copper and run across the front of the radiator, down near the bottom. The one for the power steering replaces a less substantial one that comes with the car.
Good luck... advise if any more info/description needed.
CarolinaPilot,
The coolers are mounted on the front of the radiator, you can see them if you look closely through the grill. They look like tubes that have fins.
