I don't own the Touring or Elite, but as long as your below the 5000lbs towing limit you should be ok. I towed with my previous Pilots with no issue and play to tow with my current.
Thanks for your response.I don't own the Touring or Elite, but as long as your below the 5000lbs towing limit you should be ok. I towed with my previous Pilots with no issue and play to tow with my current.
I was towing fully loaded close to the limit with passenger, equipment, and a Bayliner 185BR. Yes to the ATF cooler as it was standard in my 2013 EXL. I towed it 6hrs from NJ to NY to Lake George.Thanks for your response.
How many pounds do you tow? Are you towing a boat? Is your Pilot equipped with a ATF cooler? If so how well do most dealer's handle the installation of this accessory item? Once installed does the ATF cooler provide any additional benefit to the engine/transmission when not towing a boat?
I only have the EX-L / RES but added the towing and soon the ATF. /I would have no problem pulling a boat. A good rule of thumb I always consider is "Where" are your going to be towing. Is it mostly highway?, Are there going to be many elevation changes? etc. etc. Another thing to consider is what type of boat. Yes, most are aerodynamic enough, but you get a pontoon back there, that is basically a brick in the wind. Another good rule I use is yes your max if 5k, but take into consideration your passengers, cargo, wind drag, etc. into your weight calculations.Would you tow a boat with your Touring/Elite SUV equipped with an ATF cooler?
The owner's manual say's the maximum tow capacity is 5000 lbs.
The trailer will be a single axle with disc brakes.
What do you folks think about the Pilot's ability to tow a boat?
Agree. A chart from first-gen MDX owner's manual illustrates this point nicely.Boats are easy tows because of the aerodynamic shape, don't be afraid to tow up to the limit and be sure to use premium fuel.
I live in the upstate Albany NY region and this is the lake I'd like to tow a boat to, about (1) hour north up the Northway I-87.I towed it 6hrs from NJ to NY to Lake George.
To small for what. It's all relative to your type of boating. 18-19 foot bow rider for towing should be no issues.I live in the upstate Albany NY region and this is the lake I'd like to tow a boat to, about (1) hour north up the Northway I-87.
I do not own a boat yet, but have been considering a purchase for many years.
I'd like to buy a 24' bow rider but the weight w/trailer might easily exceed the Pilot's (Elite AWD) towing capacity.
What do you guy's think of buying a 19' bow rider, is it too small?
I have an 18' bow rider and it's been plenty big for my family of 5. If you do need (or just want) the 24' that is a lot of boat. I would consider a full-sized 4WD pickup for that tow.I live in the upstate Albany NY region and this is the lake I'd like to tow a boat to, about (1) hour north up the Northway I-87.
Absolutely! I tow an 18' Inboard / Outboard comfortably. Boat weight stats are dry weight, without fuel & gear. You are well within the Pilot's towing capacity.So do you guys think a properly equipped AWD Pilot can tow a 19' foot boat like Yamaha's AR192, with a dry trailer weight of 2935 lbs., safely?
No, my AWD Pilot is not equipped for towing. It looks as if I'd have to invest ~$1000 to add a towing package to my SUV.Absolutely! I tow an 18' Inboard / Outboard comfortably. Boat weight stats are dry weight, without fuel & gear. You are well within the Pilot's towing capacity.
I was under the impression that vehicles with a factory tow hitch came equipped with a tow package; i.e. Auxiliary transmission cooler and sometimes a higher differential gear ratio.
I quickly learned that only the Touring model comes with trailer wiring. Does it have an auxillary transmission cooler?
RESPONSE: I am a 40+yr boater, I have owned a small 16 Whaler (2200 lbs= boat/motor/trailer)style boat, and towed this easilly with my last 5 leased Odyssey's, and more recently, our 2020 Pilot. it was under 3500lbs and loaded with 5 occupants,towed very easily.I live in the upstate Albany NY region and this is the lake I'd like to tow a boat to, about (1) hour north up the Northway I-87.
