1 - 12 of 12 Posts
2016 Pilot Touring AWD
I recently installed the OEM tow electrical harness and tow hitch on our 2016 pilot touring. 1 of the 6 pre-tapped bolt holes were not tapped and in fact appeared to be the diameter of the bolt, i.e. I could slide the bolt in without any resistance. How could this happen? Has anyone seen this? Perhaps one of the assembly line robots didn't have its morning coffee...
Anyway the car is already out of warranty as I'm installing this hitch late, but I assume I'll have to take this to the stealership and hopefully there will be some fix free of charge as this is a manufacture defect. I didn't see any way of putting a nut on the top side of the undercarriage (bolts are inserted from the ground up) without pulling all of the interior panels out of the trunk bed. Maybe it could be welded too?
Fortunately it's a middle bolt (3 on each side of the hitch frame), so the frame is well supported otherwise.
If the std size bolt just slips into the hole, it is either stripped completely or it was drilled too large initially. Easiest repair would be to go to the next size larger dia bolt and rethread the hole to match. Easy DIY but you would need drills and taps, so it may be cheaper to go to a shop that installs trailer hitches, unless you can persuade the Honda Dealership to cover it under warranty.
Yes it appears to be drilled larger than intended. Curious how this could happen. Tapping with a larger bolt is a good suggestion, which I might end up doing if I can't get Honda to pay. Thanks.
Sounds like a weld nut was not installed at the factory. Might want to visit a U-Haul store and see if they can use a bolt fish wire from the top side.
I'm with @PLT383 ... weld nut was not installed. So you should not try to tap something larger in there as you would only be grabbing on the thin frame metal (say 1/16" thick) and not on a proper fastener (the nut has about 5/16ths of thread). I would start with the Honda dealer, and then a weld shop after that.
Great thanks for your advice.
Don’t forget UHaul......they’ve installed more hitches than anybody. They will know how to drop in a fish wire bolt where the weld nut is missing.
If weld nut is missing, thats a big disappointment to you. Only way to safely fix that would be to cut out a section around each hole, weld a nut on the back of each hole, weld each piece back where it came from, paint, underseal and install hitch.
Has nobody installed a hitch from etrailer.com on a vehicle that does not have factory weld nuts???? No factory weld nuts uses the fish wire method to install the hitch utilizing the factory holes. I still say have a look/ask UHaul before cutting/welding anything.
Agreed! I’ve used the fish wire method on my ‘05 CRV to install flange nuts successfully into the frame to install a hitch. I would not be interested in cutting or welding weld-nuts into the frame especially since it’s only one missing nut.
The Gen 5 CRVs do not have factory weld nuts for the hitch install......they use the fish wire, bolt, nut and backing plate method.
1 - 12 of 12 Posts
