I am the owner of a 2010 Honda Pilot. I previously owned a 2004 Honda Pilot.
I am getting vibration/shuttering in my 2010 Pilot between 35-50 Mph around 1500-1800 RPM's.
I suspect a faulty torque converter. I had the same problem in my 2004 Honda but not until about 60,000 miles.
It's hard to convince the dealers that they have a torque converter problem as no codes show up. I am convinced this is it. The problem was solved with a rebuilt transmission in my 2004 Pilot. The proof was in the pudding! I dread going through this again. The plan right now is to have a Honda tech look at it in January.
Any advice or TSB information would be helpful.
Discussion Starter #2
some have said changing the EGR can help but like I said the problem was corrected in my previous Pilot by a rebuilt transmission.
Is it specific to low temperatures? Only ask because this seems a lot like something I'm experiencing, and I'm almost certain it's just a characteristic of the VCM in low temp conditions.
In my case, it's very mild and goes away instantly with a blip of the throttle.
Discussion Starter #5
temperature not an issue with Torque converter shutter
No, the temperature doesn't seem to matter with my torque converter shutter. I followed the link and what it sounds like to me is that everyone is having torque converter issues.
Right now the plan is for a Tech from Honda to look at my vehicle.
Just to eliminate another variable. Is your CC on when this happens? Are you overriding the CC with the accelerator? Is something eg hill causing a shift down?
I am sorry toear that u r having problems with your new HONDA Pilot. But your problem sounds like the problem I have with my 2006. It hesitates or shakes when my foot is lightly on the gas around 28-32 mph. If I slam the gas pedal while its shaking, thn shakiness is gone.
Some people say its the EGR, some say its the pressure switch for the 3rd n 4th gears. But all agree that this leads to a tranny issue where te torque converter fails. I know my car is getting worse. I will trade in the car and get me a Toyota. I will never get another Honda again, unless we are talking about a Civic (or a small 4 cylinder).
I might wait and see from some members wether changing the pressure switches make a difference. I know the switches can fix delays in shifting and some even say that bad pressure switches can lead to a failure in the torque cnverter.
I had the same issue w my 2010. I found a great fix, it's called a VTM tuner ll (2). $125 takes 1 min to install, and takes out the ECO. I had oil consumption problems, engine rap, and Everytime it kicked into ECO, it had a shutter(transmission/torque converter) The rap is noticably quieter (now it sounds like a normal Honda 3.5) That tuner eliminated those issues completely. The tunner has the option to wire in a switch so u can turn the ECO option on or off. I'm averaging 16/17 mph w the tunner on(all 6 cylinders working all the time) haven't installed my on/off switch yet, but the truck runs and drives a lot better.
S-VCM is under $100 and is doing as you stated above. This, and the switch to Valvoline MaxLife ATF has eliminated the growl.
