1 - 16 of 16 Posts
Things u need
3/8 ratchet
18mm washer drain plug
20mm washer for the filler plug
2 1/4 of dual pump II honda differential fliud
Bottle transfer pump
134365
134366
Picture directions
Remember to pump until u have a stream off fluid pouring out and then quickly put back the washer with the filler plug
Thanks for the pictures! We also have an existing thread found below at the link that details the same procedure.
Thank you, oa1583. I'll be doing mine this spring when the weather warms up a bit more. I have the fluid, just been looking around for a transfer pump. The reviews on the Walmart page for the one you posted look pretty good. For $5.20 with tax added I went ahead and ordered one of them for pick up at a local store.
The pump is pretty good for the price and compare to harbor freight one for 9.99 for my previous suv x5 . Plus it has a yellow screw end cap to prevent run back which i thought was a very good idea...
But at 63k mines was darker red versus the pinkiest color or the new fluid
When was the last time it was changed? It is supposed to be done the first time around 15000 miles, and then every 30000 miles after that for normal use.
2019 Pilot Elite
Nice call out, I missed the picture scrolling.
Here's the link
Attwood Fluid Pump Walmart
For that price I'll order 2... I was at Walmart last week and they didn't have these in stock.
2019 Pilot Elite
Can anyone prepare me for the smell?
The differential fluid in my grand Cherokee smelled like hell. I used to wear double 3M masks and even today I can still smell it.
Thanks.
How could you not like the smell of well used gear oil? :)
I have no idea what the newer Pilot rear differential fluid smells like since mine is a 2005.
Oa1583 get yourself a box of the black nitrile gloves at Harbor Freight so you don't have all that nasty oil all over your hands!
2019 Pilot Elite
Thanks.
For anyone wondering, the smell is not bad at all. No masks needed.
The pump linked above worked great. I will probably buy another to keep in the garage for future uses.
I changed mine a couple of months ago and found it an easy task. Drop the spare tire for extra working space and then you can just use a small funnel with some hose attached to get the fluid in. Much easier than using one of those pumps which are designed for marine lower units. You have to get over 2 liters of fluid in there and that is a lot of pumping. Wear rubber gloves too as the stuff is nasty on your skin.
1 - 16 of 16 Posts
