So i'm looking for new tires for my 16 Pilot ..... and is looking for some A/T just for the sake of looks. I am wondering what is the largest size i can get for my OEM 18" rims that won't rub?
I can even pick up some 20" Touring rims too so any suggestions on both 18" and 20" would be great.
thank you
check out tirerack.com
they have a good selection
I’m guessing you won’t find (m)any AT tires which fit an unlifted Pilot with 20” rims.
If you’re going for looks the popular AT choice on Tacomas are BFG KO2s.
When my OEM tires wear out (maybe in less than a year!) I plan on putting these on my Pilot, and will go with the same-size as the OEM tires are. The info given below is taken from the Tire Rack website:
CONTINENTAL
TERRAINCONTACT A/T
On-/Off-Road All-Terrain
  • Size: 245/60R18 105H
  • Serv. Desc: 105H
  • UTQG: 680 A A
Presently $190.02/tire for set of 4.
However, I'll probably get these tires (and balancing/installation) @ my local Discount Tire place.
-- BR
thank you
I have on 265/50/20 on 20" rims from the 2019 model.
275/50/20 and 275/55/20 rubbed badly on my car. discount tire tested fitted the tires for free and then I drove 275/50/20 for about 1000 miles then couldn't handle the rubbing so went to nitto ridge grappler 265/50/20 they run perfectly fine on mine. very minimum rubbing. I can still full lock unlike the other sizes I had on. definitely looks bad ass.
