1 - 17 of 17 Posts
Does anybody know the Goodyear Integrity tires is directional or non-directional tires?
The manual indicates different way to rotate the tire depending on directional or non-direction tire. :confused:
OEM Tire rotation
non directional
My experience with past Goodyears is that they need balancing (and rotating) every 6000 or so miles. In this case, I would have it done with each 7500 mile oil change.
Saw many posts on the tires...decided to keep mine for the life and then switch to another brand...Michelin....talked to brother in law who had Goodyears that came on Pilot, he said they wore out in normal driving at 25.....Boo...wish I would have traded in now.
When to rotate CTs
I read an article in the Washington Post today that indicated that autos with automatic four wheel drive or traction control will need to have tires that are very close in size for the system to function propery and thus it will be necessary replace the full set of tires when the time comes rather than one or two at a time. This made me wonder about the rotation schedule for the Michelin Cross Terrains that I have. Does anyone know if the rotation schedule would be the same schedule that is recommended by Honda for the Goodyears?
Every 10,000 miles is more then adequate for the average driver. Furthermore, unless my tires feel out of balance, I do not get them balanced. I don't wany some 16 year old get nicking up my wheels taking off and putting on wheel weights.
Do you guys that it would be ok to use a 2-ton jack and raise the Pilot in the middle rather than the front and rear jack points???
Have not looked up front yet;
There is a center jack point in the back. There might be one up front.
If I jacked in the center, I would put jack stands under each side.
It is no fun getting car that has fallen off the jack back up. (Don't ask!)
Re: Have not looked up front yet;
What I meant to ask was if it was ok to use the middle of the sides of the car rather than the front and rear. IOW, can I jack up the Pilot using the frame under the front and rear doors???
I would not
The spots for jacking are strengthened more than the rest of the edge of the body.
If you REALY wanted to do this, I would build a wood saddle that picks up both jack points and spreads out any force put on "non-jack" points.
I would think a 4x4 would be OK, but a 2x6 might work better. Heck even a 2x4 might be fine.
Make sure the piece can not "roll" out (that is why a 2x4 or 2x6)
errr... speaking of jack points...
anyone know if there is a central jack point for the front? There is a beefy-looking tie-down hook up there, but I don't know what that is connected to... looks as strong as the central jack point for the rear.
continuing OCD forces me to find the OPTIMAL way to rotate my tires with the absolute MINIMUM number of ... ok, so I bought a freakin floor jack, ok and I want to try it out.
Any ideas? How do you get that front end (or even just one side) up on jack stands?
mmmPIE
mmmPIE
Yes you can use the beefy looking front jack point. I plan on using it and the rear jacking point to rotate my tires-
MG -- roger that... I will send the girlfiend under and have her check for stability :25:
Will report back soon, thanks!
Mkell, I check with Radial Tire of Silver Spring where we bought the Michelin CTs. They will rotate the tires and rebalance them, FREE, at 6,000 miles interval
Thanks hoppy, I was wondering if I should go there or have the dealership do it as part of the first maintenance I was planning at 5K. The only thing about Radial is the potential wait - When I went there I had the sense that I was the only one in the DC area that didn't know about them - there were so many cars in line. Maybe the thing to do is get there super early and wait with a big cup of coffee. It would be nice to get it done for free.
yes, getting early is a must. Plan to be there before 830am for the 9 am store opening. You want to be in the first batch of cars to go in the shop, or you have to wait 30-45 minutes for the next batch to go in.
1 - 17 of 17 Posts
