61 - 80 of 99 Posts
I'm thinking about getting the Continental CrossContact LX25 on my Pilot when the OEM tires get old. How was your experience with the OEM tires?
I have that on my 17 Touring now. Very quiet on the road and on bumps imo. It's also has a wider footprint than the OE. Very good with wet or dry pavement. Got a good discount during black Friday and an additional military discount at discount tires.
How much did you pay for the tires if you don’t mind me asking.
With the Pilot I never expect anything to be cheap =), though I'm always one to look at it all and figure out the best options. Curious between the Continental crosscontact lx sport and the Yokohama Geolandar's . . . . any preference and reasons why? Both are comparable with price it seems. Just called the Lexus dealership and could get the Yokohama's put on (with alignment) for $1030. Honda dealership for the Continental's would be 1155. Seriously appreciate all the info!
What did you get?
I have the Yokohoma's on my grand Cherokee and wanted to punch myself in the face the first month I made the switch.
Granted for that vehicle they were $85 installed compared to $125 for the Firestone destination LE2.
I'm still waiting for somone to put on a set of the 245 50/r20 High Performance Sumitomo HTR AS P02 's and tell us about how they handle for high speed conditions. 102V rated!
[/URL][/URL]
I'm going to buy a set just to complain about them even if they're the best thing since sliced bread.
Then ill complain so much you'll be forced to spend a weekend with me installing the ATF cooler, lift kit and 35 inch tires while drinking beer and chasing undesirables.
Deal?
Deal?
It says at the bottom of the box on Tirerack.com ...,
👍Consumer Recomended
You don't have to only take my word for it.
138282
Reactions: Highspeedbail
2018 EX-L AWD
I just got my Pilot (2018) last month. Although it came with perfectly adequate tires, I wanted to change to XL rated (for towing at near the 5k rating limit) and to be sure I was at the recommended rating.
I bought a set of General Altimax 245/50 R20, including a 5th for a matched full-size spare, and immediately went on a 2100 mi trip towing a > 4000# trailer - almost all highway, with some choppy / construction and forest service roads thrown in occasonally.
Overall very happy with them - no issue with noise or vibration, but the feel is definitely firmer with the Honda OEM 20 inch alloys. I think it's a really good touring tire.
I'll try to remember to post an update after trying them in snow & mountain passes.
Does the spare tire stick out from the bottom? I’m thinking about getting a full size but I’m worried it might stick out.
Is there a plan to rotate all 5 tires on the Pilot? The 5th matched full-size spare is a good idea but tends to become an unused and aged tire after 5-7 years. Putting the 5th matched full-size spare tire into the tire rotation could increase the overall tire tread life by 25%. In the jeep forums there is usually a debate on potential drive train damage from running one matched full-size spare with the other three worn tires.
Good question as that could be an issue for ground clearance. Perhaps selecting a taller aspect ratio full-size spare tire that matches the overall diameter of the main tires.
I'd be confident in saying that you will not see the full size tire.
Is there a plan to rotate all 5 tires on the Pilot? The 5th matched full-size spare is a good idea but tends to become an unused and aged tire after 5-7 years. Using the 5th matched full-size spare tire into the rotation could increase tire tread life by 25%. In the jeep forums there is usually a debate on drive train damage from running one matched full-size spare with the other three worn tires.
I'd not because it can't be mixed in without changing tire rotation direction. I only rotate front to back for that reason.
It's a spare. Mount an Otani on it. 😁
Good point. Then my historically unused full-size matching spare tire will be a cheap skinny tall tire or left over used tire to be replaced every 5-7 years.
If you have all wheel drive, won't a taller tire mess with the VTM since one tire rotates faster than the other?
For my Pilot project the 4 main tires will be 245/70R17 (30.5") and for a spare I would consider a taller aspect tire, 225/80R16 (30.18") a cheap skinny tire that matches the overall diameter. I'd rather not spend $$ for a 5th matching full-size spare tire that may remain unused and aged in 5-7 years.
I used the almost new 245-60-18 Firestone Destination LE2 for my full size on a 5th Ridgeline rim. If Honda doesn't have an issue with us using a tire that is 2"+ shorter for temporary use, I have no issue using one 1" less than what I'm running normally (and my winter tire size). I wanted the same basic width so that I can air it down if needed on the beach. The skinny compact 1/2 width spare does not go well with soft sand.
Unused and aged is OK with me. Spare tires and insurance, expenses you hope to never need.
61 - 80 of 99 Posts
