21 - 40 of 89 Posts
You may want to tighten the bolt with a torque wrench, and for that you'll need the holder. Hammering on the bolt with the same impact used to remove it risks over-stretching the bolt, and means you'll need an even bigger impact to get the bolt out next time.
Discussion Starter · #25 ·
What is the "Sport" designation? I've never heard that before....:unsure:
i don’t know but it says Sport on the title. It got all the goodies like leather seat, Navigation, USB ports etc.
The previous owner saved the sticker, here a photo of it.
147701
Discussion Starter · #26 ·
When I Googled “Sport”. It said included additional package like Nav, USB, Subwoofer. and tow package etc. This pilot got it all so I guess that what it meant EX-L Sport
Discussion Starter · #28 ·
My local auto part shop have both high lbs ft torque wrench and holder to loan out for free since I am a regular customer there.
I am thinking of buying this 3/8 drive torque for the smaller bolts. I have a 1/2 inch drive torque wrench but the shaft is very long and I am not sure that I’ll have room to torque bolts from underneath with the front end on the jack stands using my wrench.
Even I am concerned if I am going to be able to torque the crank pulley with the loaner wrench since it’s a long shaft one too but it goes up to 250 lbs ft
Crank Pulley - 19mm @ 47ft lbs then 60 degree turn
The second Crank Pulley spec I found is 181ft lbs
My torque wrench only goes up to 150ft lbs so I will have to get a loaner on this one.
47ft/lbs + 60 degree is the correct spec per the Service Manual. I did it without a holder tool by torquing to 47ft/lbs by hand then marking the bolt and pulley for 60 degrees and getting the 60 degrees with an impact. Seemed to work well enough for me.
Discussion Starter · #30 ·
Interesting and thank for the tip. I might just do it this way.
I know my battery impact won’t do the job for this so I will probably have to borrow one.
Do you know at least how many pound rating impact I will need for this task?
My IR 231c would not work it has 600 ft lbs. I had to borrow a cordless Milwaukee that has 1400 ft lbs. It came off with no problem. I was using the "special tool" heavy walled 19mm socket. I split a regular 19mm socket trying to do it with a pry bar. So, to answer your question it will need to be over 600 ft lbs. 1400 ft lbs will definitely do the job.
I did my timing belt today. I spent the extra money to be sure i got legit parts. I've read about a lot of Chinese knock offs that don't last. Everything I got was new and Honda OEM.
If you want to know your not buying counterfeit parts, buy from your local dealership or online from trusted parts dept operating out of a dealership.
Or
Just buy an Aisin Kit from RockAuto, or if you want to pay $100 more for this kit, a Napa dealer carries it.
FYI
The Aisin kit contains OEM supplier parts.
I'll take that Mitsuboshi timing belt over Honda's Gates/Unitta any day.
Or
FYI
TY. I read reviews. Happy with my purchase.
Glad your satisfied with your $433 purchase.
Not to be critical of APSG. I am in no way implying that the good folks at Hanlon Auto Service Center would sell anything but the best parts they can get. They look like good guys that have been earning a living the right way for a very long time.
147703
On buying the smaller torque wrench for the other bolts --
My 3/8-drive snap-on clicker has a scale range to 150 lbs/ft, so not enough "turn-down" available to use reliably with 6mm bolts (typ 10mm heads) that get less than 10 lbs/ft. The 8mm bolts/nuts (typ 13mm hex) usually spec at about 16lbs/ft so are pretty much the smallest I'd use that 3/8-drive on. If you have a Harbor Freight store nearby, they sell a 1/4"-drive lbs/inch clicker that will do well for those smaller bolts. Multiply the lbs/ft torque spec by 12 to get the equivalent lbs/inch setting for the smaller wrench. Your favorite POLAPS (plain old local auto parts store) may have one of those to loan, but... loaning out a torque wrench is a lot like loaning out your girlfriend -- No telling what happened to it just by looking.
Super Moderator
Torque wrenches are like Lays Potato Chips.........You can't have just one.
147754
I am humbled....
21 - 40 of 89 Posts
