1 - 20 of 23 Posts
So I was changing the timing belt today on my 2014 Pilot. I am mostly done but stopped because my stool slipped and I fell onto my chest. Bruised or broken rib...not sure. But it really hurt. So I packed it in. I was mostly done but after replacing the belt, water pump, and pulleys, I have these 2 large bolts sitting here. They are not the 2 vertical bolts going into the motor mount, I have those and these are larger than those. So while I recover from my injury and before I finish....where do these 2 bolts go? They have a 17mm head and are 3 inches long.
146804
146805
I looked under the hood of my 2006. I know it could be different. I saw a number of places that used large bolts like these, but my best guess is that they are motor mount bolts. It could be a pulley bolt, but I doubt it in your case, since the timing belt wouldn't go on right with a pulley or two missing.
As far as the ribs, I have weak ribs, and have messed mine up several times. Anymore, as soon as it happens, I'm blazing a trail to my Chiropractor, saying I have a rib out. A couple of big cracks later, and I feel a whole lot better. I have found no other solution to rib pain than this.
I have these 2 large bolts sitting here. They are not the 2 vertical bolts going into the motor mount, I have those and these larger than those. So while I recover from my injury and before I finish....where do these 2 bolts go? They have a 17mm head and are 3 inches long.
Hope you heal up well! I know you said they are not the vertical motor mount bolts but they certainly look like the bolts for the passenger side motor mount I had issues with in my TLC build.
They were too big to fit into the motor mount and besides...I have those already. And they were too big in diameter to fit there. All the new pulleys are already installed. Unless they are from a completely different vehicle / project, but I cleaned up the floor before I started.
I can think of any 17mm bolts that would be involved in a timing belt water pump job, other than the engine mount.
Possibly the bolts going horizontal for the engine mount to the engine itself? I recall there were a couple that were hidden in there...
Discussion Starter · #8 · (Edited)
Thank you, but I already installed those 3 bolts also. That portion of the engine mount is installed. It's a mystery but my wife is kinda freaking out. It's not like having bolts left over is unusual...I have a bolt or two left over from projects all the time. But nothing this large.
What bothers me is that they look like Honda bolts.
Did the kit come with new bolts that you may have used in place of these?
Discussion Starter · #11 · (Edited)
I bought the standard Aisin kit from Rock Auto. No bolts came with the kit.
By the way, I also bought the fat 19mm socket and a new impact gun. Took the crankshaft bolt off in 2 seconds. I bought the pulley holder tool thingy for bolt installation. Soon to be for sale...19mm fat socket and holder tool thingy.
Discussion Starter · #13 ·
No. I haven't got that far yet but there is only one bolt which holds that tensioner and I have that bolt still sitting right next to it.
Is there a chance you swapped these partial threaded bolts with full threaded bolts somewhere else?
Oh man...That's why I take pictures (sometimes video) of when I do a large teardown! Nothing worse that having leftover parts!
Maybe I am remembering the wrong vehicle, but isn't that passenger side bracket and mount a two part affair with like 5 large bolts total?
Make that 6 bolts, if I am reading the diagram correctly.
146834
Discussion Starter · #17 · (Edited)
A-ha! I think that's it! I didn't bolt the mount itself to the fender. It's the top 12 x 1.25 bolts. I'll have to undo some stuff and do that. Well, thank you very much. Now I have to lean on the edge of the car to finish that up and that hurts already.
I feel stupid. I would have eventually figured that out I'm sure.
I really had anxiety over this. I'm like these are Honda bolts for the engine mount. But I assumed you had it bolted. Really glad you figured it out.
1 - 20 of 23 Posts
