1 - 2 of 2 Posts
I have just about given up on a noise for the last 3 months. Come to a stop and then mild acceleration, a thud in the floorboard and sometimes can be heard and felt if you have to get out of throttle just after you hit the gas. I have changed axles,struts,brakes, compliance bushings, and everywhere I take it to be solved says the front end is tight. I really without any other clues to say what it is, but I can make it thump/pop at will and doesn’t appear to be getting worse. I’m taking all opinions at this point. I am planning on seeing the next 100k miles, and other than this, it’s been sooooo reliable. Thanks in advance to those that reply.
Discussion Starter · #2 ·
Problem solved at a Ford dealer. Loosened the body and control arms, lifted the vehicle, then let it sit back down and adjusted to spec. No more popping at all.
1 - 2 of 2 Posts
