1 - 19 of 19 Posts
Tengo una piloto 2003 con el tanque roto alguna idea de como bajarlo o remplazarlo e buscado videos de como bajarlo pero no encuentro alguien de ustedes lo a echo que debo saber algún manual que me pueda facilitar de antemano gracias
No me parece fácil pero mira en la pagina 56. Tengo eso solamente en inglés. Buena suerte, amigo.
(Disculpe, hablo español como un hijo de tres años).
Following is a video showing the fuel tank replacement for a third generation Pilot.
The procedure is probably similar for the first generation.
El siguiente es un video que muestra el reemplazo del tanque de combustible para un piloto de tercera generación.
El procedimiento es probablemente similar para la primera generación.
No fair, you used Google translate.
Google Translate.
I used my two semesters of college Spanish.
Pero he quasi todo olvidado.
Google Translate.
Yes, I used the el-google translator-idad.
But, don't I get credit for finding a video that might help the OP?
Same for my high school French studies.
The only foreign language course I took in college was organic chemistry.
Actually, the French courses came in somewhat handy, during my first job out of college, when the company set up a manufacturing operation in Sherbrooke. While the front office staff were generally willing to speak in English, once you got past 'bonjour' and 'comment allez-vous', some of the line workers either could not - or deliberately chose not - to communicate in English. Once in a while I might overhear what I perceived to be a less than flattering comment spoken in French between some of the assembly line workers. When that happened, I would go over to them and say 'excusez-moi, répéter s'il vous plaît'. The looks on their faces were priceless.
2007 Honda Pilot EX-L
@plplplpl @xGS thank you for translating or at the very least attempting to translate your comments in Spanish. Is not often that we Spanish speaking Piloteers can find a good source of information for our personal use when it comes to car maintenance and repair. Truly appreciate your help and support to the OP.
Sent from my OnePlus 7T Pro 5G McLaren Edition using Tapatalk[/USER]
Por favor explique lo que quiere decir con un tanque roto. ¿Hay fugas o hay un problema con la bomba de combustible? Se puede acceder fácilmente a la bomba de combustible por la parte trasera del vehículo. El video y la información publicados le darán una buena idea de cómo dejar caer el tanque.
Diablos amigo usted si habla expañol pero clarito!!!
Amigo dejame saber en que parte de Mexico te encuentras para darte la informacion a donde puedes conseguir el manual del sistema de combustible en tu localidad.
Uno no sale con una hermosa niña mexicana de buena familia sin aprender algo de español en el proceso. Es una buena relación con la madre, si nada más.
Nice!
Fair enough then, and the main thing is you tried to help. And a good video is worth a thousand words -- in any language.
As for assembly line workers, don't take it personally; they're famous for cussing a blue streak -- in any language.
To paraphrase Paul Harvey: And now we want to know... the rest of the story. :)
But good on you for learning a second language and trying to use it. And French can be something of a challenge.
Next time, bypass the line workers and approach a demoiselle. That's when you'll truly be glad you put in all that effort to learn French. It's a different kind of organic chemistry. :)
Discussion Starter · #18 ·
[QUOTE = "plplplpl, publicación: 1649745, miembro: 161441"]
No me parece fácil pero mira en la página 56. Tengo eso solo en inglés. Buena suerte, amigo.
[/CITAR]
Muchas gracias amigo me sirvio
Discussion Starter · #19 ·
[QUOTE = "xGS, publicación: 1649751, miembro: 8809"]
[MEDIA = youtube] ok0Fsxm_VJo [/ MEDIA]
[/CITAR]
Gracias muy util
1 - 19 of 19 Posts
