1 - 13 of 13 Posts
Good evening. We have tailgate rust under the rear handle. There are some posts about it but my question is did anyone get it fixed by the dealer after the 3 year surface corrosion warranty? Our rust was minor but has deteriorated in the past 2 months. We never thought too much about it until recently when it became very visible. You can easily see it if you're stopped in a car behind us. We were told it's not covered because we're in Year 4 but it really reflects badly on Honda. It's too big of a spot on a portion of the car that doesn't see stone chips!
So..has anyone had any luck? If not I might just put a "Ask me about my rusty $48,000 Honda" bumper sticker over it and shoot for IG fame!
This is our second Honda and the experience has been OK (ish). Not as good as with our Accord. It actual seems more expensive to maintain than our BMW X5 with 250,000 kms on it!
Get that fixed, then sell it or trade it in while you still can. Seeing rust at the 4 year mark is not a good sign and may be symptomatic of a larger problem going forward. This is especially concerning given that it's hidden behind the handle. Who knows what else lurks underneath (i.e., other fixtures). You need to cut your losses ASAP.
Snip... snip... snip... It actual seems more expensive to maintain than our BMW X5 with 250,000 kms on it!
Are you sure you aren’t confusing maintenance (scheduled replacement of filters, belts, hoses & fluids, adjustments, cleaning and lubrication, etc) with repairs (things that need to be replaced due to failure such as sway bar links, power lock actuators, alternators, etc)?
I know from experience that genuine BMW maintenance items (filters, belts, hoses & fluids), genuine BMW wear & tear items (batteries, brake pads, etc) and genuine BMW repair parts tend to cost much more, (often two or three times as much) than the equivalent Honda parts.
If you look under the handle you will see a plastic cover that can rub on the painted surface exposing the bare metal. Rust will start quickly there given our salty winters here. I check mine a while ago and there is a 1/8" gap all along the edge away from the door. You can see it when you have the gate open and look under the handle and it would be easy to get it misaligned causing the rubbing. Just fix the spot and get the car rust checked if you are going to keep it a while.
When I see rust stains seeping out of a vehicle fixture, regardless of manufacturer, I just cringe. As Canadians, especially in northern Ontario and Quebec, this means we're fighting a losing battle. First line of defense is how well manufacturers prepare the vehicle for paint application. If that's not done right, dump it.
Can you take a pic of what you're talking about?
Most of the time rust starts as a chip or scratch which exposes the bare metal. Best defense is a close inspection of the finish and keeping all the chips and scratches touched up before rust gets a hold. If the paint is peeling or flaking off, then it is definitely a paint prep issue.
evilc76
Welcome and thanks for registering at piloteers.org. We are glad you have chosen to be part of the community and we hope you enjoy your stay.
Please take a moment to look over the FAQ section. If you need assistance please use the “message” function to contact any staff member.
If you haven’t already, don’t forget to register at the Honda Owners web site. It is full of information you may find useful about your particular Honda vehicle(s).
Enjoy and all the best,
Daltongang
Here you go.
The residue you see in the crevices is just from the Krown rustproofing I had done back in Jan this year.
Not to threadjack, but contemplating going the Krown route here in Michigan on our new 2020. Would love your thoughts on it. The idea of drilling for application worries me a bit.
I have been using Krown and RustCheck for years and with our harsh winters, it is the only rust protection that really works. If I was planning to keep a vehicle longer than 3yrs, which I tend to do, I would not hesitate to get this done before winter hits. It is cheap protection IMO and the only downside is that it is a little messy after you get it done and there is a slight smell for a few days. They only drilled one small hole inside each of the rear door posts and plugged them afterwards so you don't even notice them. If it really bothers you, I have heard that you can ask them not to drill holes and they will oblige. They recommend that you get it done every year but that depends on how much winter driving you do. For me, every couple of years is good enough. I had mine done when we purchased it and it was around $100cdn with the CAA/AAA discount.
I JUST had my entire tailgate removed and repainted on my 2017 EXL White Diamond colour Pilot. The plastic spoiler on the top of the tailgate was all peeling and then when I inspected the tailgate i found rust bubbles all under my tailgate release handle along that trim piece where it meets the metal. I live in Canada so the dealer contacted Honda Canada and they didn't hesitate to pay for it all plus a rental for the 4 days in the body shop. My body shop has a lifetime warranty on their work so I'll be interested to see if it comes back again or not. If so they can fix it again!
Funny because everywhere else on the car the paint is perfect and durable.
That seems to be a problem area on the 3rd gens and I think the plastic trim is rubbing through the paint exposing bare metal and the rust starts there. I did notice a couple of small spots in that same area on my 16EXL and have since touched them up. You don't expect to see that on a 3yr old vehicle though.
1 - 13 of 13 Posts
