Just recently I noticed my tailgate handle and rear window release not working. However, I can release my rear window from the key.
Is there a fuse that would affect these?
If the tailgate latch doesn't think it's closed all the way it won't let either the gate or the window buttons work. If you can't get your tailgate to open, from the inside you'll have to release a plastic cover from the tailgate plastic trim (in the middle and at the bottom of the tailgate). Inside there is a manual lever you can actuate to get your tailgate to open. Give it a good slam shut and see if the buttons work.
Okay I will give it a shot this evening. Thank you.
