I'm guessing you blew the fuse for that circuit.
Sent from my SM-N950U using Tapatalk
So I have tried everything from checking all fuses to the door locks, accessories, etc. which were good. I disconnected the new battery and after a few minutes reconnected it again. Still nothing.
The Pilot still has a full warranty from electrical to engine. I have dropped it off and they are running diagnostics.
After several hours, they called me and said they still couldn't figure it out. They were not receiving any error codes on their test but They knew something was off. They said it is possible it has something to do with the multi plex (assuming the motherboard that controls everything). They are still checking but once they figure it out, I will post. They did say that it was weird that everything was working fine one minute and then the next minute the locking mechanism and rear camera stopped.
I am having the very same problem. Please post what the dealer found out about the issue. The 20 amp fuse for post 29 is good and is not the problem. THANKSSo I have tried everything from checking all fuses to the door locks, accessories, etc. which were good. I disconnected the new battery and after a few minutes reconnected it again. Still nothing.
Any chance you figured it out? Same issue suddenly on my 2015 sans the battery issues. Just out of nowhere, tailgate, window hatch and backup camera are out.I am having the very same problem. Please post what the dealer found out about the issue. The 20 amp fuse for post 29 is good and is not the problem. THANKS
