I have a 2005 honda pilot and only the left small light or tail light works. Everything else works, stop, signal works. Change the bulbs and nothing, help please. Is not the small lights fuse.
Welcome to the forum. I’m not completely sure what works and what doesn’t work. Please clearly state what isn’t working so we can try to help you resolve the issue.
Post a picture so we can see exactly.
You sure you have the right bulb in there? Some are dual filament.
Pull the lightbulb out of the socket. If it’s a dual filament bulb, check that both filaments are intact. Additionally check the socket for corrosion or broken/loose wiring and the bulb contacts for corrosion.
Reactions: plplplpl
