All,
I decided to change my rear sway bar links today. What a PITA! By the grace of God, I successfully removed the driver side sway bar link. It was NOT an easy task but I did it.
The passenger side not so much. I used everything from a Sawzall to a cut off wheel. I couldn't get that sucker to budge. Now I'm stuck with flatten metal in the rear that constantly spins when I turn the bolt. I just can't figure it out.
What have you used to get past this nightmare. The nut and the stripped hex head is on the other side. I welcome any and all suggestions.
Sent from my SM-N960U using Tapatalk
