I have 7900 K on and I still have this problem. When I have two people in the car, every-time I go over a speed bump, my rear suspension makes a bad noise. It sounds like bushing lacking lubrication. Anyone else has this problem?
"Max speed"???? What kind of bumps and at what speed?hondalover said:I get a clicking noise at drivers side strut area when I go over the bump in slow speed and max speed. Is there a problem if not fixed?
This will probably be solved by waiting 2 -3 seconds before starting the Pilot - that's all you need to do - it allows the vehicle to recognize the computer chip in the key - part of the security system. Search: "Starting Problems Revisited" thread1. TROUBLE STARTING, USUALLY AFTER VEHICLE SITS OVERNIGHT BUT HAS HAPPENED AT OTHER TIMES AS WELL.
This could be a tough one - search "70mph vibration" and "egr valve" for some info. Hopefully yours is a simple tire/wheel balancing issue, and not one of the more serious problems encountered here.2. VIBRATION AT SPEEDS 70MPH AND ABOVE
Search "right front", "clunk" or other similar noise sounds. A few members have had problems with broken strut mounts, or even broken struts or shocks. This should be easily found and fixed.3. LOUD KNOCK SEEMS TO BECOMING FROM RIGHT SIDE FRONT AND CAN BE HEARD ONLY OVER BUMPY DIRT ROAD AT VERY LOW SPEED, LESS THAN 15MPH.
