Surviving the dreaded P0420 Code (Cat Converter) 1st Gen There Is Hope!
645 Views 5 Replies 4 Participants Last post by  Nail Grease
My 2008 EX-L started throwing a CEL with a P0420 fault code about a year ago at 215,000 miles. Currently at 235k miles, all original parts in the exhaust/emissions system. Cleared the code with my Actron reader and it came back sporadically about 4 times. Each time it cleared and stayed off for a couple/few months, no performance or gas mileage issues noted. Then the dreaded “California SMOG check required” shows up in the mail.
In May, I got with my local independent mechanic who tells me 100% of the time its the Bank 1 Catalytic Converter and that it will fail SMOG with that fault. (Note - he also does SMOG tests) That checks with everything I’ve read in this forum, so we agree that he’ll order the CARB compliant one from Honda and will let me know when it’s in. Estimate for the whole job is $1,800. ($1,400 parts). The back order pushes two times and in late July he tells me it will now be September at best before they’ll have parts on hand. My registration expires 31 July…
So I got a second opinion from another equally trusted mechanic (who does NOT do SMOG testing). He reports that if I can get the Fault to clear and all monitors to set to ready, it should pass smog. That was easy enough to do, but comes with the risk that something trips on the way to the SMOG station leading to a failed test and me parking the car until I can throw $1,800 at a mechanic to throw an new Cat in it. Risk taken (with a quick code scan a block from the test station), Test passed, and 2 more years of owning and operating this amazingly reliable vehicle in Southern California enabled.
Lessons learned: 1. A mechanic who also does SMOG testing will probably not give advice which undermines the ‘sanctity‘ of the SMOG test process. 2. Don’t wait to get a second opinion on any job over $500.
· Registered
well im in cali and had the exact same issue, not sure if you have read the forums at all but i got mine to clear by installing a defouler on bank 1 sensor 2 (took 2 seconds to install) i then ran premium gas 4 tanks though the car and cleared teh code witha odbII reader. it has clearned the issue and passed smog just fine. i did also order a non carb compliant bank 1 cat for 120 on ebay but never had to install it. (i did also change the spark plugs but doubt it did much)
now if you go to the smog place adn teh check engine light goes on of course you dont try to smog and come back when t is off. i drove with expired tags since may till i got around to installing the defouler (15$?)
· Registered
2008 EX-L 200,000+ miles and going strong
A long overdue thanks for that reply and references. Did you notice any performance or fuel mileage improvement after installing the defouler + 4 tanks of premium?
· Registered
Home of the 306k 2012 V6 Honda Crosstour
If that 2008 is a 2wd, I’d disable the VCM. Doing so ended my emission codes permanently. Disregard if 4WD.
· Registered
I installed the svcm 1000 miles after passing smog, I don't think using premium or a defouler would give you better gas mileage. The svcm has taken 2mpg from me but hopefully that lost milage will even out in future repairs it may or may not help. I'll keep you posted. And I still have a extra new bank 1 cat when ever it fails. (Was only 120 compared to a cali carb version for 1200)
· Registered
Id replace the EGR valve.
Id also do a throttle body cleaning with a throttle reset.
I assume you have a new/clean air filter, installed correctly, box lid sealed. Intake hose is leak/crack free.
I agree, premium gas does little. I’d look for 87 octane with fuel additives (top tier).
