Hello, new to page. I had a question to see if anybody has tried or may have info about key areas.
227,000mi bought/235,000 currently
Been working on it since I purchased nothing too serious.
Recently I added new tires 245/70_16 (learning new fuel curve) to go with my 2in suspension lift "spacers" . I notice when hitting big dips at highway speeds the CV axles make a slight hum.
Since new springs, shocks, control arms+bushings were installed my thoughts are the drive train is at its limit and could use a drop for easement.
I know there is a couple of vendors/manufacturers for 1in, not opposed at all in buying. However, I have lifted everything I ever own and probably make my own kit.
QUESTION: Has anybody ever gone 1.5 or even 2in with subframe drop?
I'm aware to watch for hoses, wiring, and pinch points. Honestly I'm not the biggest fan of the simple sleeve spacers on engine mounts- would address this an actual block spacer. And i know exhaust will have to be dropped , rear shock spacers longer.
Things I'm curious about is steering shaft how much slack it has in sleeve? Radiator hoses are at there max with store bought kit? Brake lines too?
2in drop would be hard gamble but wondering 1.5in is doable.
