1 - 8 of 8 Posts
Lowered front subframe about an inch to change stabilizer bar bushing put everything back now steering is tough any ideas was perfect before
Any PS fluid leaks? Open the bottle and see if you get a whirlpool at idle. There should not be bubbles and foaming.
None of the above crazy it was fine till i changed bushings even lowered a second time to check everthing
Do you have the whirlpool of PS fluid? You should. If it's quiet in the bottle, then PS pump is not working.
Then I am fresh out of ideas.
Yesterday I lowered both rear corners of the subframe by about 2" to do the bushings myself. No issues so far. The subframe would not lower any more than that, not sure what held it. I used a pry bar to lower it at least as far as the screws would go.
Thanks for your help I think just coincidence I think rack has problem dropped at Honda tough when your laying on your back
1 - 8 of 8 Posts
