Would you recommend changing all the rubber parts with the struts or can I get away with just doing the struts?
The rubber associated with the strut itself, definitely replace. The other suspension components that have rubber is a judgement call. I’d replace dry cracked rubber parts. Sway bar bushings will begin to waller out and be less effective. Cracked rubber boots (ball joints, sway bar links ,CV axles) can eventually rupture loosing the grease.Would you recommend changing all the rubber parts with the struts or can I get away with just doing the struts?
Didya end up breaking or twisting the axle?Please learn from my mistake. When you pull down the strut do NOT put it on the CV axles. Take a piece of cardboard and put it on top of the cv axle. Ask me why I’m sharing that with you.
No I put it down on the boot. Got it all back together and took it for a test drive and when I got back I saw grease everywhere. So I got to then replace the cv axle.Didya end up breaking or twisting the axle?
damn, when I get around to getting all the needed parts together, I'll make sure to be careful.No I put it down on the boot. Got it all back together and took it for a test drive and when I got back I saw grease everywhere. So I got to then replace the cv axle.
Is it absolutely necessary to replace the strut mount bearing (51726-SZA-A01 )?The rubber associated with the strut itself, definitely replace. The other suspension components that have rubber is a judgement call. I’d replace dry cracked rubber parts. Sway bar bushings will begin to waller out and be less effective. Cracked rubber boots (ball joints, sway bar links ,CV axles) can eventually rupture loosing the grease.
No, I’ve reused, but as with anything rubber, it isn’t as good old as it is new. On a 2010, Me personally, I’d replace. If you can take it apart first to examine is the only way I consider reusing, if it looks to be in good shape.Is it absolutely necessary to replace the strut mount bearing (51726-SZA-A01 )?
Need to support the knuckle with a floor jack on disassembly. Hopefully the cv axle is okSo I did a stupid and ended up popping out the CV axle boot when putting the strut back in... Well popped it out a couple times
My issue was reassembly lol. Getting it off I had no issue specifically because I had the jack supported. But yes hopefully the CV axle is ok. Might be lacking some grease thoNeed to support the knuckle with a floor jack on disassembly. Hopefully the cv axle is ok
