Do the whole thing. It's not terribly more expensive and a lot less hassle.
So, what year?
Is it best to replace the entire strut assembly with the spring or can I use the current spring that is on my pilot?
Either strut replacement procedure can be done but spring+strut combos are easier and safer for the home mechanic. For a little more $$ ready-to-install spring+strut combos are readily available. If your Pilot is high mileage the springs, bearing plates etc. will be worn and should also be inspected/replaced.
