1 - 20 of 21 Posts
I hate those little donut tires...
Thanks JohnDrak for the new spare! (PS I think he still has two for sale)...
pic 1
Discussion Starter #2
pic2
should have taken this one in the sunlight
Discussion Starter #3
pic3
should have taken this one from a different angle
Discussion Starter #4
last pic
The full size wheel is much more visible (it is fully positioned/tightened).
Re: last pic
A Hitch and Hitch-step fixes that issue! :2:
Re: last pic
Nice pics :) The spare looks really punny in comparision.
Just wondering if there would be more wear and tear on the tire and the alloy wheel due to them being closer to the ground ...
Discussion Starter #7
N-Jay, lol you are a bad influence! :p
Yolk, I don't foresee it making any kind of real contact. I'll keep you updated on how dirty it gets or if I see any kind of scuffing.
It does not hit anything.
As for how dirty, lets see its hung under the vehicle! Duh!:2: :2:
When I added my full size spare I bought a vinyl tire cover from my local auto parts store to cover it up. It looks much nicer under the Pilot and it will add protection to the rim and tire.
2003 WH Pilot EX
Cargo Tray
Full Nose Mask
Running Boards
Rear Mud Flaps
Full Size Spare with cover
1994 Accord Wagon (200K on odometer)
2001 Odyssey White EX
Discussion Starter #10
As we used to say, "Someone is Thinking!"... :)
Is the cover open side up or open side down?
colorider said:
That was a joke - right?
:jester:
Lets see?
Cover, open side up.
Makes a nice bag to catch any water dirt and salt that gets above the tire. I bet by spring you have a well salt soaked wheel.
Cover, open side down.
Protects the exposed side of the tire but not the wheel, but does keep off much of what will sit on top of the wheel (Face side).
Either way i think it is unneccesary. The wheel and tire stored under the car are no worse protected than the ones being used.
Premium Member
N_Jay said:
Lets see?
Good points - I actually thought that either one of us was not yet awake or that you were joking!
The only thing I have noticed (other than the obvious exposure to dirt) is that if you drive on unpaved roads a great deal, whatever is under there is going to get beat to $hit from the gravel being thrown up. A painted steel wheel will eventually be pretty well sand-blasted.
Will a full size spare still fit if you have a trailer hitch?:confused:
jay said:
Yes and no.
I read (and saw from the pictures) that it will if you have the OEM hitch. There's not enough clearance with a DrawTite hitch. See this thread:
http://www.piloteers.org/forums/showthread.php?s=&threadid=5066&highlight=Drawtite
But the fact that your full size spare (and therefor your flat tire) will not fit is offset buty the few $$ you save! :)
P.S. Insuring that you only get a flat tire when you have the back filled with things that "Must Not" become dirty! (So says Murphy)
Full size spare fits perfectly with the HONDA OEM hitch. Some of the aftermarket hitches do interfere.
I have my spare installed after first coating the spare with tire dressing. ( UV protection.) I use the full size spare in the 5 tire rotation. Doesn't seem to get unreasonably dirty back there and has NEVER been scuffed or made any contact with the road or obstructions.
Premium Member
Bravo!!! :29:
I'm betting that you are one of very few that use the full-size spare in the rotation pattern. Actually, I only use the FS spare in the rotation until I am ready to replace the first set of tires. Then I keep the "best of the 5" for the spare and only buy 4 new tires - and use a 4-tire rotation from that point on.
YMMV
colorider said:
Bravo!!! :29:
YMMV
Know what you mean. I like to use the 5 tire rotation because if consistently done properly, all five wear at about the same rate and the full set lasts a bit longer than if you only rotated 4. When it's time to replace, I replace all 5 and have a matched set that provides optimal car handling and breaking since all four operating tires are the same age and similar in wear.
Works for me, but you are right, the 4 tire approach works fine and is in fact the only way you can go if you have directional tires or rims. (the Pilot EX rims and tires are not directional)
I would be careful with a multiple-year old left over tire being my spare once it gets on in years, tires do rot and deteriorate separately from usage wear.
1 - 20 of 21 Posts
