Loud static and screen flutter on the Navi screen just began. Upon turning off the car, everything back to normal...but only for a while. Any ideas how to repair this issue? Thanks
Looks like your head unit is going - might consider looking for a used one on ebay, or consider aftermarket. If you are comfortable poking around electronics, you could try puilling the unit, opening it up and looking for bulging/leaking capacitors. If there are any, replacing them MIGHT fix the issue.
If you pull the head end check for loose connections/wiring, especially grounds.
