My 2011 Honda Pilot starter keeps cranking after starting, only after adding gas to the vehicle. We have replaced all the evap stuff (forgive my lack of technical terminology),I think it is called purge valve, replaced it under the car & under the hood & switches & it still does the same thing. Many hundreds of dollars later, it is still malfunctioning. We have a long awaited trip which we will leave on in about six days. Any input is greatly appreciated!!
Oh, & charcoal canister has also been replaced. Thanks!
Sounds like a stuck purge valve. It's something to do with that evap system. Did you test your old purge valve to see if it worked? Have you made sure you have power and control back at the tank?
Sent from my SM-N960U1 using Tapatalk
Yes, we replaced all the parts on this. I will check with the mechanic about he power & control. I know we put a new switch on.
