Did you check the spark plugs to see if they had oil on the electrode?
Make sure you walk the seal over the tube. Set the valve cover down, and wiggle it as you press down, and get your fingers down there and push the seal down around the tube. Otherwise it gets pinched between the cover and tube, and you get leaks and it destroys the seal. There is not enough pressure, nor is there any other way the seal would tear like that. The fit is tight which gives it the sealing ability. This also makes it difficult to go over the seal the first time or 2. I always make sure each seal has made it around the tube before installing the bolts. I use my fingernails and run it around the tube, pushing the seal down.
