Feel with your finger that the spark plug tube seal isn't pinched between the tube and cover. You have to walk the seal around the tube especially when new. Wiggling helps, but walking them in is almost a must.
It is well known that Felpro sucks and should not be used, again as you said, only use genuine Honda valve cover gaskets, price is not to be a concern here (and it's not like they cost an arm and a leg anyway). And valve cover gasket replacement may be necessary at other times other than valve adjustment = leaking.Damn Felpro! For all fellow piloteers: if you adjust valve lash, do yourself a favor and get the OEM valve cover gasket!
YES YES YES.And retorque to spec. Our spark plugs sometimes have a tendency to loosen and even back out.
Did I press fit tube seals? yes, I used a large socket and gently pressed it. I did get 14K miles since the valve adjustment. Could my craftsmanship be improved? Probably. After all, it was the first and probably last time I do a valve lash adjustment.you replaced the valve cover outermost gasket but did you do the press fit tube seals at the same time?
if not, don't blame felpro. I went with a beck/arnley kit and no leaks anywhere. just clean the oil out of the tube before reinstalling the plug.
also those covers require a special torque sequence to properly seal it down.
everything in the factory service manual
This happened after the spouse returned from grocery shopping with a mixed highway + local driving: the car struggled to start, and after it started, it stalled immediately. There was some notable vibration from the engine bay before it stalled. For the first 2 tries, it left a strong gasoline odor. After a 3rd start, I pumped gas for a min or so and the car got into the normal working state. Once in this state, everything worked fine and I drove the car on the road without issue. It even stopped at STOP signs and traffic lights without stalling or abnormal vibration.
[Update 1]: After turning on/off a few times, the symptom is now repeatable: if right foot rests on brake, the car cranks strong but it won’t start; if/when cranking the car and at the same time pumping gas (ie right foot not on brake pedal), the car can start -- is the foot not on brake a sign that something went bad? Once started and pumped gas for a few seconds, the car drives just fine – it doesn’t stall in subsequent stops at STOP signs or at red lights.
[Update 2]: When the hard-to-start-then-stall occurred, there was no CEL or any warning light on the instrument panel initially. After many on/off tries, now the engine light and VTM-4 light are on.
Vehicle repair history: it’s a 2004 EX-L, 4WD with 203K miles:
- diff fluid changed in 2019 at 172K
- Starter and alternator are still original
- spark plugs were replaced with NGK at 152K miles in 2017
- EGR valve was replaced in 2017 at 155K miles
- timing belt and water pump n all belts are replaced at 157K miles in 2017
- 2 O2 sensors (the ‘04 EXL only has 2 O2 sensors) were replaced in 2018 at 164K miles
- valve adjustment done & PCV replaced in 2021 at 189K mile
- The battery was replaced in Nov, 2022 and is practically new
I searched and the past working fixes include: valve adjustment; fixing timing belt jump one tooth. Neither seems the cause of the problem I am experience.
Where do I look next?
Howdy,
I just had a similar issue with my wife's 2004 Pilot. It was very intermittent, but long story short, I believe you need to replace the main relay, under the dash, near the steering column. I spent the extra and bought the Honda, O.E. part.
I also remember, when the green security light would light up, it would start up normally. If it didn't light up, it would crank, but not start. At one point, the vehicle would crank and not start.
I would tap the relay; the light would then come on and I then knew it was going to start.
Good luck, I hope this helps,
K-Lap
P.S.
You mentioned at one point, when it was acting up, you could smell fuel, so that eliminates the fuel pump and other fuel delivery items...
I am tackling IAC valve. I got to the point where throttle body is detached and I cleaned it thoroughly.The surge is Idle Air Control Valve. The shaking is likely related. Remove the Throttle body and clean it really well. Do not move the Butterfly Valve. I would say clean it without removing the Throttle Body, but I bet the gasket is bad. Replace with a new one, and make sure to get the old off. Do not scratch the aluminum surface. You can use a plastic razer blade sold at Walmart. Make sure to dry it before re-installing it. If you don't the liquid-carbon created from cleaning will dry and cause the butterfly valve to stick, or could settle at the bottom of the butterfly valve and cause it to restrict airflow.
Razer blades
Yeah, after cutting a deep groove, and used the flat head screwdriver, it didn't budge: the screw is rusted and it's really tight, even after I soaked it w/ WD-40 overnight. It's probably not a good idea to continue in this route as there were shredded metal pieces from twisting. If the metal on the screw head is broken into pieces, it will be really a long day.If you have a quality vice grip, you can get on the screw head from the side and twist it off. If you made a good cut on the screw head you can also use plyers or something similar on the flathead to help twist the screwdriver giving you more leverage.
impact driver, yes. Flathead bit, no. I didn't know that I can use a flathead bit with impact.Do you own an impact driver with a flathead bit?
