Well, I figured it was going to be a fight. Doused them with PB Blaster, and so far, getting nowhere. Upper one on the left side turns slightly if I beat on it, but the whole thing is turning. Lower one won't budge at all and access with the wrench isn't very good. Stinks that the links that are on there are round on the other side so you can't hold them very well. Tried bracing a wrench with the Allen drive as I beat on the upper one, and it's just trying to walk out.
So, any tips? I'm thinking let the Blaster soak for a while, maybe go at it with the fire wrench. Lower one looks like a nut splitter might work. Upper one is recessed into the bracket, but maybe the impact wrench could help persuade it.
Strange thing, the replacement links have Zerk fittings. Haven't seen those in a while. They also have hexes on the inboard side, so at least I can hold them if I have to do it again.
