1 - 1 of 1 Posts
Just wanted to give you a heads up;
Tthere is going to be an update the software here on 11/23/2015. Site will be down from around 9:30am to 1:00pm EST, maybe earlier. The update should only take 2 hours to complete and when it does you will be the first to know. In case there are any issues here are some things you can expect.
1) The site should be significantly faster.
We have applied every modern technique to speed up page load and tested with all modern browsers. We want the forum to be extremely fast and easy to use.
2) Mobile Friendly.
The site will work much better in mobile and tablet views.
We've started applying responsive design, and have designed and tested against android and iPhone devices, Android tablets, and iPads. If you are sitting at your desk or on your couch, or just on your phone, the site will work much better than it did before, and load fast. We are still working on improving the experience even further in the months to come, but we wanted to launch this as quickly as we could.
3) Welcome! We detailed and got a new paint job!
The homepage is bright, crisp and clean. We wanted the first page users saw to look beautiful, so that when a new guest arrives and is debating whether to join, they see a beautiful doorway, and they walk right in. We can also use this newly minted front page to showcase a Ride of the Month winner or other community related news and announcements.
As a forum member you can choose to use the new design (which will be placed ON by default) or you can go back to the old design. We ask that you give it a chance and see if you like it. Like anything new, it will be unfamiliar at first, but we suspect that the speed difference will make you want to use this new one. If you do decide to switch back, the link is at the bottom left of each forum page, you pull down and select the theme called "Piloteers Classic".
4) Garages will be featured on the site
You can show off your Pilot, You can post pictures in your garage and share it with others.
5)Social Media Connect
Users will be able to register with Facebook, Twitter or Google+ meaning faster legitimate registrations.
1 - 1 of 1 Posts
