1 - 2 of 2 Posts
Will the side view mirrors that contain the heated mirrors and side directional, fit and function using the stock installed wiring on the early model 2009 with regular heated mirrors ? Anyone experience them? I recently busted the passenger side and was looking for a replace when I saw these.
They will fit fine, but you would need to run additional wiring for the turn signals to function. I replaced mirrors on my 2013 EX, needed to tap into turn signal wires on my gauge cluster, run those wires into the doors, crimp on pins and add those pins to the mirror connectors. (one wire per mirror) The grounds for turn signals can be spliced to grounds for heaters - either inside the mirror, or by adding two jumpered pins to connectors.
1 - 2 of 2 Posts
