I recently installed the OEM Side Steps on my new Starlight Silver Pilot and I thought I would share what I learned. It was very easy to do, and only took a couple of hours. (One of which was spent finding the right tools).
The first thing you have to do is remove the clips that are covering the holes for the bolts. The instructions say to use the "clip remover" to do this, but of course I didn't have one of these. They can be easily removed by punching in the middle part of the clip in with a small screwdriver and then pulling them out with needle nose pliers. Punching in the middle releases the clip.
Secondly, the instructions clearly state that you need a 13 mm socket and wrench, but I found after the first couple of bolts that a 12.7 mm socket was a much better fit. (Before you spend too much time looking for your 12.7 mm socket
, it's the one with 1/2 on it ).
Lastly, it is best to leave all of the bolts relatively loose until you have everything in place. This gives you the ability to adjust the steps so that the spacing is equal all the way down. I found that I had to pull out on the front part of the step, and push in toward the back to get an even fit.
Please feel free to ask any questions.
Next up... Rear mudguards.
