1 - 2 of 2 Posts
I purchased a SGII v4.53 and have been using it successfully in my 2019 RL to monitor VCM mode and ATF temperature for a week. I tried using it in my 2019 Pilot EX-L and got some strange behavior. It connects fine and displays parameters normally, however it locks out several menus in the Driver‘s display when its connected. For example, the Maintenance Menu displays an orange lock symbol and can not be accessed when the SGII is connected. Also the SG will go into sleep mode while the engine is running. I‘ll send a help request to Linear Logic but just wondering if others have experienced similar problems in 2019+ Pilots.
Just curious if that same menu is grayed out when you’re out of Park with the scanner unplugged? I don’t have a 2019 but when I put my 2016 in “drive” a lot of my menus are grayed out for safety including the maintenance menu. So I don’t know if it’s a scanner issue or if it’s the car itself.
1 - 2 of 2 Posts
