1 - 2 of 2 Posts
I am looking at buying a 2005 pilot ex-l with trans issues. I found a transmission for a 2008 Ridgeline for cheap. Both are AWD. Will this work?
Thanks in advance
Probably not, but to be sure, find the transmission model number on both and compare. The transmission number is on a white tag, and is a series of letters and numbers. My 2003 is a BVGA. Your 2005 may be a PVGA? What is the Ridgeline?
Another way to check: go to car-part.com and do a search for a junkyard replacement. Only compatible parts will be listed, and the source vehicles will be detailed there. See if Ridgeline comes up as a donor vehicle in the search.
1 - 2 of 2 Posts
